General Tech Electrical Relays
PAUL161
When installing relays on a positive ground system, do we just split the power wire and insert the relay? Headlights, horns, wiper motor etc. Where does the relay get it's power from to operate the switch? do I have to install a third wire? I'm a hammer and chisel guy, not an electrician. I can follow a wiring schematic, but beyond that I'm lost. Any help on this? PJ
Sarastro
In short, the power that originally went to the (say) headlights goes to the relay coil. Then, you run another wire from the battery to the switch contacts of the relay, then the headlight wire to the other switch contact. Positive and negative ground are the same story.
I'm out of my office now, but I can scan a sketch for you when I get back. Meanwhile, here's what I did on my TD; I hope it helps:
https://www.nonlintec.com/mgtd/electrics/#wiring
JPSmit
Oh and it isn't hard to do
PAUL161
PAUL161
Thanks fellas, Much appreciated! You've explained it very well! :encouragement: Steve, did you mount your relays under the dash on the firewall, or ? PJ
Platinum
Durnit, Paul!! The relay is aught more than a load absorbing "thingie" to take the load off the switch. A "pre-switch switch"!
Sarastro
Here's a sketch I posted on another forum:
https://www.912bbs.org/vb/showthrea...n-switch-relay-same-thing&p=320834#post320834
It's down around the bottom of the page.
Actually, I put all the relays into a box and mounted it right behind the battery box. I also put a set of modern fuses on the outside of the box (so they're easily accessible) and have large connectors for wiring to the dash and harness. That way I can remove the box if I need to fix something. Perhaps a bit more than necessary, but I'm an electrogeek, so this kind of thing must be expected. You can see pictures of this if you use the link in my previous post and scroll down a bit.
If it's just a couple of relays, I think any convenient location should be fine. Probably on the back side of the dash is easiest, is out of sight, and is not likely to get kicked accidentally. You can get relays that have a nice mounting tab with a screw hole, and that makes mounting the relays infinitely easier.
PAUL161
PAUL161
Well Doc, I wasn't very good at math either! :highly_amused:
PAUL161
PAUL161
Steve, Thanks a bunch for your input along with the photos. Sure looks like your not an amateur in this type of work. Being up under the dash, I should be able to connect the original type harness to the relays in place of the switches and the non original wiring going to the switches should be well out of sight. Thanks again, :encouragement: PJ
Keoke
Brinkerhoff
OK , I'll bite , at the risk of being pummeled by all you electrical experts out there. I've had numerous British cars with the original systems and none of them ever had a problem with the switches failing. Aren't you trying to fix a problem that doesn't exist?
JPSmit
Only partly. There a few (I think) very good reasons for using relays.
1. 40 year old car = 40 year old wiring. These cars were never really intended to last 40 years. So, the wire (and really the covers) will degrade over time - I am still using the original wiring on my car and want to do everything I can to keep the current load light. Using a Relay effectively adds a few new circuits to the electrical system.
2. 40 year old cars = 40 year old switches. In many ways the real culprit is not the wiring, it is the switches. Over time oxidation increases the resistance of the switches, producing heat and lowering efficiency. Using the switch to switch the circuit but not power it is a good solution.
3. Relays = Brighter lights Lucas (and British Leyland) tended to cheap out on wiring. Thus most of our cars have lighter gauge wiring than they really need. Of course I can't find it just now, but have seen calculations of LBC's loosing as much as 1/4 of their voltage in the run from the battery to the headlights. So, instead of 12 volts, they are getting 8-10. With a relay you can run Halogens and be confident of a fuller voltage.
For me, Relays fall in the category of "sensible upgrades" - along with such things as seatbelts, and modern voltage regulators. They make the car safer and/or more reliable.
David_DuBois
The last two posts kind of hit on the ultimate solution. The relays greatly reduce the load put on the switch (particularly for the headlights) Having a relay in the circuit, the current for the headlights through the switch is reduced from several amps to a few milli-amps, the relay then doing the actual switching of the higher current. This saves the switch, but does very little for increasing the amount of light from the headlights.
When redoing the lighting circuit in our early MGB, I ran a single 12 gauge wire from the main 12 volt source to a set of relay contacts and from the relay contacts to the lights. The relay was then controlled by the original 16 gauge (or the British equivalent) from the switch. By using the heavier wire going to the relay contacts and on to the lights, I achieved greater light output from the headlights.
Done correctly, installing relays, one protects the switch while also increasing the light output from the lights. It also allows the use of today's higher output headlights (which draw considerably more current than the OEM headlights.
Cheers,
Keoke
Well put David.
On the other hand, a significant improvement in the existing lamp's brightness can be obtained by simply otaining your switched power to the lights from the starter solenoid and using a 16 AWG wire to the relay.
PAUL161
PAUL161
Dave, My harness is new, but you have me wondering if being new is enough? The wires are vinyl covered with only the outer covering to match the original. I don't have the original wiring to compare the new to the old, so I'm at a loss there. The original wiring was so bad and patched up, I just trashed all of it. So what do you think, just use the new harness as is and hook them up to the relays, or? PJ
Platinum
As Steve suggested, the realys are best located under-dash, close to the switches. Less messing with running longer trigger wiring and "kinder" to your new harness.
Ya know I wuz jus' pushin' yer laig, Paul!
Sarastro
A couple of points worth noting. First, a large part of the resistance is in the connections and switches, not just the wiring. Adding a relay can reduce that part of the resistance, which is why cars with relays usually have noticeably brighter lights. Second, these cars were not designed to be on the road 60 years later. In the 50s and 60s, it was accepted that the maximum lifetime of a car was about 10 years and 100,000 miles, so it was pointless to make the parts as good as they could be. All the electrical parts now are likely to be near the end of their lives, so the electrical contacts in switches are probably pretty bad. And, of course, anything that minimizes the load on them should increase reliability.
Today, 200,000 miles is nothing special, and the AVERAGE age of cars in the US is now about 10 years. I suspect that improved electrical systems are at least part of the reason for that.
D Adding electrical relays, to save old stuff Triumph 16
71tr electrical relays Triumph 2
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
