Electrical problem
Lin
I need a little help getting started with solving this problem:
I am installing a new alternator in my son's Bugeye. We had a Lucas alternator in it before. I have just installed a mitsubishi unit. Had to do a little bracket work and the usual fitting, but in the end I was pleased with the effort.
I had a three prong plug on the Lucas alt. Big spade brown wire from the battery, two little ones - one for the brown/yellow wire that I think is the indicator warning light to the speedo, through the ignition I believe. I forget what the other small wire is, sourced from the no longer used voltage regulator.
On the mitsubishi alternator, the big brown wire (big spade connector) from the battery connects to a scew terminal on the back of the unit. The other two small wires from the Lucas plug were spliced into the Mitsubishi two prong plastic plug and plugged into the back of the alternator.
I then checked my battery -fully charged, and turned on the ignition. Got nothing, No fuel pump ticking, no fuel gauge jumping into action. I have spark to the alternator through the brown wire from the battery. The starter works fine. But, nothing at the ignition switch. No obvious lose wires and everything worked before the alternator change over. No blown fuses.
Can anyone help me with a troubleshooting plan of attack? Probably something silly or stupid that I overlooked.
Thanks.
Lin
1960 BT7 in restoration
1959 Bugeye
piman
Hello Lin,
the usual feed to the ignition is a heavy brown wire taken from the starter solenoid (Where the battery and alternator cable also connects). Did you disturb any of those connections?
What do you mean by "I have spark to the alternator"?
If you test for power by shorting to earth you can cause all sorts of damage to electronic components and to the battery.
Alec
GregW
Hi Lin,
I’m not familiar with the Bugeye, but here goes. I installed a Delco alt in my BJ8. The wire that charges the battery (output) has two connections on the alternator. One of those connections is in the two-prong plug. The other wire is the brown/ yellow wire. The original brown/green wire I cut out completely. Here is the only handy photo I have. Without knowing how the Mitsubishi is supposed to be hooked up, it’s kind of a crapshoot.
Lin
Lin
Greg,
If I understand, you say that there are two connections: "The wire that charges the battery (output) has two connections on the alternator. One of those connections is in the two-prong plug. The other wire is the brown/ yellow wire."
But your image shows the brown/yellow wire in the two-prong plug? Huh?
Lin
GregW
Hi Lin,
Sorry, I could have been clearer. The red wire in the photo comes out of the 2-prong plug and attaches to a post on the back of the alternator. Another wire on the same post goes to the battery side of the starter solenoid. The brown/yellow wire goes to voltage regulator, then on to the charging light in the tach. The Delco has an internal regulator so my original regulator on the firewall is just a distribution box now.
dklawson
If I remember, the 10SI Delco shown above has a feedback wire on terminal "2" to the main output stud. I think this is a feedback connection for the "sense" circuit. I'm not familiar with what's on the Mitsubishi.
Lin
Lin
Thanks to everyone for the help. I think I have it figured out now. I have to go out of town for a few days. I will report back next week with an update!
Lin
1959 Bugeye
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
B TR2/3/3A Electrical Problem Triumph 13
H Electrical problem I need to solve Spridgets 7
B TR2/3/3A Another Electrical Problem Triumph 2
Gerry M TR6 Another electrical problem Triumph 1
J TR6 Electrical ignition problem Triumph 9
5 TR2/3/3A TR3 electrical problem ignition or generator??? Triumph 12
B Electrical problem British Motor Corp 4
6 Electrical problem Austin Healey 10
D Coil and/or Tach Electrical Problem MG 8
Anthony_S Electrical problem Triumph 12
T TR6 Electrical Problem with TR6 Triumph 11
bigjones Interesting electrical problem Spridgets 9
1 Electrical/guage problem MG 8
kyreb1862 MGB 77 MGB Electrical Problem MG 16
kyreb1862 Electrical System Problem Need Help ASAP MG 7
J Electrical problem with flasher relay? Austin Healey 10
scott_74 Electrical Problem Spridgets 20
Got_All_4 TR2/3/3A TR3A Electrical and Missing Problem Triumph 8
M TR2/3/3A TR3 A Electrical problem Triumph 8
Thor How to troubleshoot this electrical problem Spridgets 14
A Electrical Problem Austin Healey 8
jjbunn Electrical problem: car wont start Triumph 23
J T-Series Electrical Problem: headlight switch turns starter MG 28
B Electrical problem / Fuel octane MG 12
G Spitfire Help with Spitfire electrical problem Triumph 13
hondo402000 TR6 TR6 electrical problem continue Triumph 23
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
1 Help on a bad problem, electrical, fuel? MG 12
Monark192 Solution to electrical problem MG 8
RSMTR8 Wedge TR8 Headlight/Electrical Problem Triumph 11
kyreb1862 Got a Whole New Electrical Problem MG 10
C electrical problem MG 2
Lin Electrical Problem Spridgets 5
Russ Austin Electrical Problem Triumph 4
mgbmedic Electrical Problem MG 7
T Electrical Problem MG 10
TR6Stuart TR6 TR6 Electrical Problem Triumph 10
Y Electrical Problem MG 10
D Electrical problem [imagine that] Spridgets 9
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
