I'm writing about an electrical accident that caused a few lighting wires to severely overheat and one wire burned completely through. The car is a 1960 Sprite. I'm not much educated about auto wiring and want to learn from forum members. The wiring was damaged when my Dad mistakenly turned on the Ignition Switch and the Lighting Switch on the Sprite (with a fresh battery); and then, walked away for a couple hours or so. I am wondering if the damage that happened when the switch was left on fits with what you would expect could happen because of turning on (and leaving on) the Ignition Switch and Lighting Switch with a new battery (and a partially installed new wiring harness).
The car had recently had a brand-new wiring harness installed (following a carpet fire in the cockpit area that severely damaged all of the under-dash wiring). Only a limited number of wires in the new wiring harness were connected -- these included the wires needed to start the engine and the wires to the lights in the rear end of the car. All of the other lighting wires in the front of the car and in the cockpit were disconnected, plus wires for accessories were disconnected.
The car was being re-restored when the carpet fire occurred; and then, the wires that accidentally burned by turning on the ignition and leaving it on was a second (and much milder) wiring accident.
The wires that were damaged severely when the Ignition Switch was left on include one of two (all Red) lighting wires that originate from one connection point on the Ignition Switch. In other words, these are the two (Red) lighting wires that are attached to one screw-on connector on the Ignition Switch. One of these wires goes through the firewall and it was burned bad enough to sever the wire (near the Ignition Switch).
(The other Red lighting wire that connects to the Ignition Switch seems OK, with only some superficial damage to the plastic covering of the wire, where it was lying along next to the wire that burned up. That [unburned] wire [with damage to its plastic covering] supplies the small light bulbs of the Panel. Those Panel lighting wires were all disconnected when the damage occurred. Also, the switch for those lights was completely off the car when the damage occurred.)
The Red lighting wire that burned in two makes a junction under the hood and divides to go two directions, with one Red lighting wire going forward to the lights on the hood; and, the other Red lighting wire going back through the firewall, all the way back to the lights on the back of the car.
(The Red lighting wire that goes forward to the front of the hood appears to have no damage to it. None of the lights on the front of the car are connected to wiring when the Ignition Switch was left on.)
The right-hand tail-light had three wires connected to it; and, at that tail-light fixture, it has some damaged plastic covering on the Red lighting supply wire. The wiring for that tail-light is grounded. (The pieces of Red supply wire going to the left-hand tail-light and the Red wire to the license-plate light [which I have been told doesn’t have a fuse] appear to be fine.)
Do these findings (a severely damaged Red lighting wire that goes forward from the Ignition Switch and then through the firewall, and, a mildly damaged Red lighting wire that goes backward through the firewall and all the way back to the right-hand tail-light) fit with what damage you would have expected to happen by leaving on the Ignition Switch with a new battery? For example, would you have predicted damage to some other wires? Would you have expected the worst damage to be near the Ignition Switch?
Thanks.
Thanks.
