Your wiring diagram should be right about the wiper motor wiring. Also, if I understood you right, the fuel gauge is still wrong. There should never be a brown/yellow wire there. Instead, it goes between the D post on the regulator and the D post on the generator. There should also never be a white wire there. Also, the only wires ever connected to that thumb screw terminal on the fuel gauge must be black grounds. That contacts both the gauge case and the back of the dash. Any violation of any of these will surely burn something down.
Please do yourself a really big favor. Disconnect everything first and follow my first suggestion. Using your ohmmeter, check all wires in the harness for continuity from end to end and put a tape lable on each end of each wire. If you are not sure of the purpose just put matching numbers on both ends. This will be a great help later Also check for any internal shorts between wires within the same bundle. Make any corrections necessary or tape new wires to the outside if you can't correct otherwise. Then add circuits back, one at a time, following the diagram explicitly and ignoring how it was connected before, checking each one for end to end continuity as well as for unintended shorts to ground. When that all checks out, it is safe to apply the voltage for testing. Only when that circuit is complete and tested should you go on to the next. You will note that some circuits will depend on others being installed first. For example, the white wire from ignition to the fuse must be made before any of the green circuits will work. The regulator is required for the ignition, etc.
Do not continue using that 30 amp breaker. Remember none of these circuits, with the possible exception of the horn, consume more that 8 or 10 amps at the very outside. Actually, if you check each one for shorts and find none then the big breaker is all right. For that matter, you shouldn't blow any more fuses either. But let's be safe here. Use a small 10 amp fuse and be ready to cut the power at the first sign of overload, whether the fuse blose or not.
Hi Guest!
What I was talking about was a more normal situation with components functioning reasonably right. True enough in the event of a catastrophic component failure (battery or regulator) but not under normal or usual circumstances.
