tinman58
I have a TR3 with a supercharger. (Moss Motors ). While out on a drive thru the hills on Saturday the TR felt like it kept wanting to run out of gas. It would spit and sputter for a bit as I would pull over and after a few moments it would be back to normal. After about 70 miles of this %^$# I made it home. The fuel regulator is set at 4.5 . Today I hooked up a fuel pressure gauge in line between the pressure reg. and the Carb. At idle 4.5 Normal acceleration 3, under hard acceleration it would even go down to the negative side as I would let off it would climb very slow. I do not know much about the electric pumps. I do know that they either work or don't work. This one works but not good enough or am I doing something wrong or ??????
