Actually since I installed electronic ignition I can install a usb receptacle for my smartphone if I want to.Where do you plug in your Smartphone?
Hi Guest!
Or ... of course we could ... just maybe ...
drive less?
Not at sea, but on site so no ships involved. There are 5 fueling stations around the world showcasing this technology.An ideal (although not yet tested that I know of) senario would involve using solar power and/or wind energy to extract hydrogen from water at sea - ships could move around to collect the most favorable wind/sun conditions and then return the hydrogen to shore where it could be distributed as fuel.
I know a bit first hand of that. Had two separate systems on the boat to do that, altho the prime objective was 0xygen, the Hydrogen being pumped overboard to recombine (with zero bubbles?) with sea water.Explained to me in the generating and maintenance arenas, first you bring in salt water, then you distill it (still). Then you take the pure water, run electricity through the base of the column, Hydrogen generated up one column, oxygen up the other.So, you need POWER to pump in salt water, POWER to distill the water (and discharge the brine with another pump requiring POWER), then run through the process to split out the oxygen and hydrogen, requiring more POWER, then pumps to compress the gasses required into a vessel, more POWER....and the net gain/loss is?......I always thought the hydrogen vehicle concept was more effective. An ideal (although not yet tested that I know of) scenario would involve using solar power and/or wind energy to extract hydrogen from water at sea - ships could move around to collect the most favorable wind/sun conditions and then return the hydrogen to shore where it could be distributed as fuel.
I always thought the hydrogen vehicle concept was more effective. Range is limited by energy density and batteries that can deliver adequate energy in a small enough space are painfully expensive and require exotic materials. Hydrogen can give more energy storage in the physical space.
Limited range? According to the video the hybrid model goes 600 miles. And you still need āenergyā to recharge batteries.Nothing new in compressed air vehicles. Very limited range - and you still need energy to compress the air!
