nevets
I fired up my Elan for the first time in over a month and discovered that my clutch was not functional, meaning that when the pedal was depressed the clutch would not disengage. When I tried starting the engine with the car in gear and with the clutch pedal fully depressed, the car lurched forward powered by the started motor. Obviously the clutch pedal was not doing its job. No sign of leaks from the master or slave cylinders and plenty of fluid. Maybe air got into the system? Perhaps worn seals? Any thoughts or advice would be greatly appreciated. Thanks.
