EFI is FINISHED!!
Glen_B
/bcforum/images/%%GRAEMLIN_URL%%/banana.gif
I now consider the EFI project finished! I dialled in the high HP/boosted part of the fuelling table this weekend and burned the changes to the chip. The computer is now stand-alone and totally in control of the engine. Spark timing and air-fuel ratio are controlled and yield excellent results. 10lbs of boost without pinging on 91 octane!!!
Clean plugs and easy cold starts.
Anyone who says you can't fuel inject an A-series is welcome to stop by and take a ride with me.
I took a 60 mile ride yeaterday and the performance was excellent, mileage to follow with next fillup. Gas mileage appears to be in the neighborhood of 30MPG.
The only remaining detail is to fabricate an air cleaner. Trivial.
Glen Byrns
How's the power?
The power is, how shall I put this?, AWESOME. This car has always had the power to dust any other conventional carburetted Spridget. Now its faster. No stagger when I jump on the pedal and the boost rises quickly to 10 lbs.
If its your thing, you could easily stand the car in a puddle of its smoking rubber.
I haven't plugged in the G-tech yet, but the butt-dyno says its at least 110HP flywheel. Best is the mid to high throttle response. Stomp on it in third and it still jumps up and pulls like a Clydesdale. Torque is VERY good.
With the exception of the up-turned noses of the originality crowd, I can't see the downside of this project. Those up-turned noses can only be seen for a second or two before they get real small in the rearview.
My bigget hope is that I've replaced my last piston. Adjustable timing, mixture and over-rev controls are built into the computer and are my shield now.
Glen Byrns
Nice work, Glen. Faster is good. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Sounds like it was a good move.
My hero!
EFI Specifics:
Single Lucas 44lb/hr injector shoots into the short adaptor tube that links the turbo and the Ford 1.9L throttle body.
Summit Racing fuel pump and boost sensitive fuel pressure regulator. Megasquirt v3.0 running MS&Extra code, with relay board. GM sensors placed in head and intake manifold for intake and coolant temps. (open element sensor in the intake for fast response).
Dizzy is fixed, Crane optical sensor used to send tach signal to computer. Timing is set in the timing tables to vary between 49deg BTDC at low loads or cruise to a low of 22deg BTDC at 10 lbs of boost.
Closed loop mixture control based on the Innovative motorsports LC-1 wide-band sensor allows the use of an Air/fuel ratio table that I have set for 16:1 under low loads up to 12.8:1 at 10lbs of boost.
I'll post some pics over the next few days. I drove it to work today........WOOOO HOOOO!!!!!!
Glen Byrns
This sounds really fascinating. I'd love to read a detailed description of the project, what all the considerations and choices were, if you ever feel like writing it up. Sounds like this would make a great web page.
