Ebay Oil Pump
ok thanks
I wonder if the quality is any better
phil
I saw the superflow pump, I thought it was more for a racing motor.
what are using the APT pump on.
Phil
The high volume oil pump just move more volume at high RPM, on a street engine not really as important. Most vendor are selling these pumps will the steel backplate, and they work fine. The oil pump on a A-series engine is not a weak point, in short any of the pumps will work fine.
Be sure that you are not using that for a 1275 or 1500 engine. It is a "pin drive" pump which would require mods to fit anything newer than a 1098.
Bill
Understood. I just didn't know if you had read some of Phils' earlier posts regarding what he was working on.
I've run star drives in some of the 948's in order to take advantage of the wider cam lobes.
Jeff
Thanks for keeping an eye on me, it is for the 1098, I think I might bid on it.
we got 15 to 20 cm of new snow last night and still snowing. Its a day for the snow blower. Sur hope it is warmer in San Fransico
Happy New Year
