bobh
This is a little risky. I read a post from a local club this morning that is a good example of what Swift6 mentioned above.
Keep in mind that imagination plays a large part in improvisation. This owner found an interesting solution to his problem. "Anyway, my 71 Spitfire carburetor diaphragm had very small cracks all the way around it…so there was insufficient vacuum available to run the engine above 3000 rpm…I covered the diaphragm with a thin coat of the goop and then ordered a new diaphragm. Well the car runs so good with the goop fix, that I still have the new diaphragm in the trunk."
Hi Guest!
