Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
I have replaced many later Midget tail lamps with the early 2 piece ones. I think they just look nicer.
It's pretty much a direct bolt in replacement.
I am not sure if it was old to new or new to old but one way you have to enlarge one of the holes just a bit. It really doesn't matter since it will not be see with either lamp.
Check first to ensure the plinth for the lights matches up with the new lens, sizewise and in the location of the bulbs/ reflectors. Other than that, they should fit, I just seem to remember that the backing plate differs.
-Wm.
You have to have the entire early assembly...then, all you have to do is bolt up & wire them in...oh, lights are in different positions inside housing so wiring will go to different locations...just check the wiring diagram
