T
TRDejaVu
So my nice little project to do the narrow belt conversion has take a sideways turn. As the rad was out I thought that I would take out some play in the inner tie rod ball joints, so out came the rack.
I did this 30+ years ago and discovered that I had over shimmed it when the rod broke; most inconvenient when miles from home. So does anyone know:
- what the shim procedure is?
- what wear points elsewhere in the rack will make the difference between worn and worn out?
Thanks
Thanks
