T
TRDejaVu
Since the barn find went back on the road last fall I have always had to have a smooth motion with the clutch when pulling away from a stop, otherwise very occasionally it would shudder a little bit, but nothing serious. Tonight I let someone else drive the car and their clutch technique was not good. High revs and clutch slip to get the car moving on a hill start. When I finally drove the car home I noticed that it now shudders when pulling away from a stop and also a little bit through the second gear change as well. The original clutch condition is unknown as I didn't have to pull the gearbox when I was putting the car back on the road.
What causes the shudder?
Are there any instances where it will settle down again or am I going to have to pull the gearbox for a look see, in which case I might just as well change the clutch?
What damage can occur by trying to drive through this for the rest of the summer and fall?
Hi Guest!
