AUSMHLY
The smith gauges in our Healeys had E10 2.2watt incandescent bulbs. Why was the 2.2 watt bulb used when it really doesn't provide enough lumens? An E10 5 watt will also fit and and lights up the gauge much better. Is it the amount of heat generated by the bulbs an issue, why was the 2.2 was used?
I spent some time on this issue a while back and experimented with E10 bulbs in both incandescent and LED. I found the LED kalvin a bit too white/blue for my vintage taste. So I drilled one then two more holes in the bottom of the speed and tach gauges, and added 2.2w bulbs. I found the stock bulb placement at the top center and the two bulbs at the bottom across from the high beam and generator light bulbs spread the light evenly. In the gas and oil/water gauge I installed a 5w bulb. My concern was how hot that bulb gets. Seems to be ok, for over the years, no problem with those two gauges.
I'm now helping a friend restore his 66 BJ8 and he'd like me to modify his gauges so they are brighter.
So I'm revisiting the LED vs incandescent issue. I like the warm light (vintage look) the incandescent bulbs provide, but I'm concerned about the heat. LED's don't have that issue, so here I go again.
LED have come a long way since I played around with this back in the day. Now they can provide 180 degrees or more dispersion, vs the focused beam when they first came out. I've played with a few "warm white" led's recently and find they are a bit too blue/white vs incandescent. I believe warm white should be in the 2700-3000 Kelvin. I'd prefer to install LED for non heat issue and the bonus of the bulb may out last the car.
Moss and a bunch of other vintage sellers sell E10 LEDs but they don't publish the kelvin. I'm concerned they are over 3000 kalvin, blue/white light.
As much fun as buying and testing bunches of E10 LED's is, any one know of a "warm white"- Vintage lumens ... that disperses 180 degrees or more, has the vintage shade of yellow/white and provides more lumens then the 2.2 filament? Where is that glass slipper LED I'm searching for?
I'm not going to spend as much time on this bulb issue as I did years ago. Three 2.2w incandescent in the speed/tach and one 5w in the gas, water/oil is a hugh improvement over stock set up.
