E-Type steering wheel
DJames
Recently purchased a new steering wheel (wood had shattered on the old one) for my '69 E. New wheel came with a packet of 6 Allen flat head screws and nuts. I removed the horn button and found the the original wheel is held to the hub by what looks like flat head rivets, maybe? Before I screw something up, is the wheel riveted to the hub and if so do you just grind or try to drill out the rivet from the back hub side?
Thanks,
dj
Grantura_MKI
I would purchase a new boss(hub) for the wheel, as your old one can be restored.
Yes, they are riveted from the factory. Is the new wheel a copy of the original, or a Nardi, etc??
DJames
Got it from Welsh Ent. Looks very much like the original. My old one had some cracks in the wood and one day I had a mini Mag light in my right front jeans pocket. When I exited the car the Maglight caught on the wheel and shattered the wood. That could be restored?
Thanks,
dj
Grantura_MKI
If you have the pieces of wood, it can be done.
Just do a Maserati wheel that was broken in several places along with the inlay missing bits. A better alternative than spending 4K on a new one!
DJames
I think I will take your advise and buy a new hub. I believe I have all the pieces of the old one (I have it wrapped in one of those fake leather lace on covers so I can use it). Can you recommend a company that could renew it?
Thanks
dj
Grantura_MKI
Good idea.
I do wheels on the cars I restore, but don’t do outside work as I am always busy.
Have a look in Hemings motor news in the services offered section.
Good luck.
toysrrus Orig. E-Type Steering Wheel For Sale: Jaguar 5
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
V 65 E-Type Steering Column Adjustment Jaguar 2
V E-Type Steering Column Adjustment Jaguar 4
bighealeysource Steering box oil - type ? Austin Healey 3
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
D E Type S1 1966 2+2 4.2L steering column Jaguar 8
S S-Type Squeakey Steering Jaguar 11
B E-Type steering rack boots Jaguar 2
D E type steering Jaguar 1
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
M Series 3 E-Type Bonnet Jaguar Classifieds 0
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 0
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
M e-type siries 1.5 shock abosorbers Jaguar 3
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
M E Type 4.2 engine rebuild Jaguar 4
DrEntropy E-Type windshield FYI: Jaguar 1
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
Graham H TR2/3/3A A type overdrive Triumph 6
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
M E-type series 1 plastic dash vents Jaguar 1
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D '69 E-Type sputters, coughs & dies Jaguar 20
Boink Left-hand Drive E-type at Windsor Jaguar 5
H Clutch-Type Differential Austin Healey 5
M Brass F type radiator shell build Restoration & Tools 11
NutmegCT Type L SU fuel pump Austin Healey 8
Basil Terrible way to spot an E-type Spotted 4
