jjbunn
	How much travel should there be on the gas pedal, from no throttle to fully depressed? Mine seems to have only about an inch or so, which can't be right. Also, the pedal feels "loose", as if there's a lot of play in the attachment.
I've looked at the complicated linkage between the pedal and the carbs, and am a little overwhelmed by its complexity. I'd welcome some advice on how to check out the adjustment of it.
Thanks!
Thanks!
				 Hi Guest!
Hi Guest!
 but were afraid to ask:
but were afraid to ask:  STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the
STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the  smilie in place of the real @
