E-Type 6 cyl Engine Rebuild in San Diego
PYanni
et al,
I'm in need of an engine rebuild and was wondering if there were any good shops in San Diego? I'm willing to go North up towards LA if need be.
Thanks,
Phil
Grantura_MKI
Just finished one on a 1970 E-Type. Not a cheap motor to build.
Cheers, David. /ubbthreads/images/graemlins/cheers.gif
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
M Series 3 E-Type Bonnet Jaguar Classifieds 0
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 0
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
M e-type siries 1.5 shock abosorbers Jaguar 3
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
M E Type 4.2 engine rebuild Jaguar 4
D E-Type steering wheel Jaguar 6
DrEntropy E-Type windshield FYI: Jaguar 1
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
Graham H TR2/3/3A A type overdrive Triumph 6
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
M E-type series 1 plastic dash vents Jaguar 1
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D '69 E-Type sputters, coughs & dies Jaguar 20
Boink Left-hand Drive E-type at Windsor Jaguar 5
H Clutch-Type Differential Austin Healey 5
M Brass F type radiator shell build Restoration & Tools 11
NutmegCT Type L SU fuel pump Austin Healey 8
Basil Terrible way to spot an E-type Spotted 4
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
PC X-type shooting brake Spotted 0
J MGB 1974 1/2 MGB gasoline type MG 5
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
M S1 e type radio console Jaguar 2
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
CJD TR2/3/3A A type Overdrive Seal Triumph 9
