When I brought the car (BN7 1960) amoungst the boxes of components were a refurbished starter and dynamo. The starter has been fitted to the newly rebuilt engine and works fine. However the simple task of fitting the dynamo has got me stumped.
When mounting the dynamo on the two top bolts the space between the dynamo mounting faces is wider than the distance across the engine bracket lugs by about 1/2". To check the pulley position I ran a straight edge across from the water pump pulley front face to the dynamo pulley front face. With the block rear mounting lug against the inside face of the dynamo rear mounting the pulley faces line up, but I'm left with having to take up the gap with packing shims. This can't be right, as if to confirm this the sliding bottom mount hits the middle of the bottom dynamo flange rather than abutting one side to alow fitment of the tensioning bolt.
May be I have an incorrect dynamo, any suggestions as to which model I should have for a BN7 or what I'm doing wrong?
Some good news having primed the oil pump and lubricated the bores when I cranked the engine on the starter, without plugs installed, I was getting an indicated 50/55 psi on the oil gauge.
