Finally, the TR7 is working. I drove it and it actually went pretty well. Turns out the thermostat I had bought and installed six months ago was bad, so it was overheating. Put the old one back in, and it's fine.
So over the course of 8 months:
-two sets of carb mounts broke, including the second set fixed with high-strength adhesive.
-old temp sender
-new faulty temp sender
-new thermostat was incorrect part
-clutch stuck from sitting (no cost for breaking it loose with hard drive in first gear.)
The brakes are dragging a little. I'll see if I can jar them loose with some good thumps on the pedal.
But man it was fun to drift it around corners again!!!
-old temp sender
