G
Well, my 6 has been cloistered away in the garage since last fall getting various things done to it. Winter cold slowed me down a bit and I didn't really do much more than collect parts until the spring temps broke. She got a new set of rear hubs and rebuilt rear axles with all new U-joints first. Then a quick spin around the neighborhood just to make sure I got everything back in the way it was supposed to go. Then I tore the front of the motor off to finally real seal it and get rid of the pesky oil leak that developed after I did the bearings and sump last fall. Found the leak right where I though, at the bottom of the front engine plate where it meets the saddle bar. Engine plate gasket was shot at the lower edge. Cleaned and painted the plate, timing cover, balancer, and the fan extension, and put it all back together with new gaskets and timing oil seal and sleeve. Now it's tight and (so far) leak free. Flushed the rad and the block, and finally hooked up the home made cold air intake I bought all the parts for a year ago, and mounted driving lights to the front end. What do you think of the lights? I love 'em. I agonized over drilling my bumper for weeks, it was straight as a pin and rust and ding free. Chrome is a bit worn thin though. In the end I realized that if I get tired of the look it's no big deal. Although a bit pricey these are not rare parts, I could dig up a good used one in a few weeks or just buy a repro. Then I replaced the junky unknown brand of spin on oil filter adapter that was on the car when I bought it (and which leaked like crazy) with a new Mocal unit from BPNW. The old adapter was tapped for oil cooler lines, but the DPO had just put a loop hose in instead of buying the cooler, brilliant. Also adjusted my front hubs and greased a bunch of stuff all over the car.
Got it running again Friday night and cleaned her up yesterday. The final result (notice my oh so oxidized hood, paint has seen better days).
Was so good to take her for a spin, even for just 20 minutes. Made me remember why I bough this car. Next up project wise at the end of the season will be an electric cooling fan, but I want to do the Bosch alternator upgrade before that, which I'll pick up in a week or two. Haven't wired the lights yet for the same reason. At least I can now make our local Friday night cruise in this week, and I'll drive her to the Red Mill Brit only car show coming up in two weeks. At least the wife can't complain now that the car hasn't moved. /ubbthreads/images/graemlins/smirk.gif
