Graham Ayers
I have a wee problem with Bea. (1972 Roadster)
Preamble: - When I got the car the hinge on the driver's vent window was broken. The window & frame assy was replaced while it was at the Sportscar Factory. (Another job I did not ask to be done.)
Since then I have had the windscreen off to install the bolts in the center rod holding plate. (Not done at the S.F.)
Upon reinstallation I found that there was a 1/2" gap between the driver's vent window & the windscreen seal. (I cannot swear that it was/wasn't there previously).
At first I couldn't figure out why. Now it appears that putting the bolts in the center rod holding plate did not allow the w/screen to move back far enough. (Possibly why the bolts were not installed?)
So I loosened the w/screen & took the center rod mount plate bolts out again & got it to move back far enough that it & drvr's v/window seal actually meet.
So far so good?
Now for the problem: Said drvr's v/window is 1/2" too for OUT. The window channel at the bottom is as near to the door skin as it will go (in fact touching). The bolt is as far west as the slotted hole in the bracket will allow.
I measured from the center of the w/screen to the top of both v/windows. There is a 1/2" difference - the left is 1/2" further out.
Is it possible that the channel could have been bent (straightened) slightly? I know 'anything' is possible perhaps the word should be 'likely'. Factoring everything else it seems to be the only thing I can think of.
Or - are all roadster vent windows the same year to year. Perhaps an earlier/later one had been installed.
Thoughts?
Sorry about the length of this diatribe, I need to fill you in on the details to have it make sense.
Regards, Graham
So far so good?
Thoughts?
Regards, Graham
