Atrus
I need to replace the hard brake line from the union on the passenger fender to the caliper on the driver front of the car.
I see that it goes between the frame and steering rack. Are there any clamps or anything in there securing it? Can I remove the line without removing the rack?
If I need to remove the rack, how hard is that? I have to change my tie rod ends out anyway, so if it has to be removed it would at least make that process a little easier. Currently the entire front suspension is off the car, so no need to worry about getting the tie rod ends loose as they already are.
