TimK
I removed my transmission 2 years ago and replaced the clutch and pressure plate and replaced the steady bracket rubber bushings with polyurethane bushings. Since then I have an annoying vibration which buzzes the whole car at engine speeds between 2000-2500 rpm. The vibration is much more noticeable while driving, but is much less when revving the engine at idle. There have been recent posts about damper de-lamination causing crank failure, but my damper looks fine -- it spins smoothly. How do you know if a damper is bad? Or could it just be the solid poly bushings transmitting/magnifying the engine vibrations, or could the pressure plate be unbalanced?
