Drive/Propshaft Bolt Torque Spec?
cechiodo
Hello,
Needed to move the driveshaft to get to the handbrake in the tunnel (another story) and found the nylocs holding the driveshaft & rearend flanges together were loose. Maybe 1/32 play between the shaft and axel flanges. Seems odd. Is this correct? If not, what should these should be torqued too?
Thank you.
Chris
vette
Hi Chris, this is going to sound like a smart alex answer but it is not. Make them as tight as you can get them with an average size 3/8th drive rachet handle and a approx 6" open end or box wrench. If your a really big muscular guy don't make them quite that tight. I believe you are talking about the bolts that hold the rear universal joint to the pinion flange. I don't believe nylocs are original to any Healey. My BJ7 has nuts with lockwashers. After tightening good by hand I have never had any of these come loose. Not on my Vette either, and I can tell you the six u-joints on my Vette get stressed alot more than the Healey's U-joints. Also I mentioned an approx 6" wrench because if you put a longer box wrench on these bolts you can strip the threads. Cheers: Dave.
steveg
Real tight - don't think they have a torque spec other than a generic one for a 3/8" bolt.
You should replace the nylocs. FWIW - I'm using grade-8 bolts with grade-8 stover all-metal locknuts. Never had anything loosen up.
For suspenders, use some threadlocker.
Brinkerhoff
Its important to torque them crosswise , then again. They will draw up tighter the second time you try. I think they more than likely weren't tightened properly to start with, rather than worked themselves loose. The rears are hard to get two open end wrenches on from underneath.
C
cechiodo
Guys,
Thanks for all the feedback on this, lots of good stuff here. I'm planning on replacing the bolts/nuts as recommended, adding blue thread-locker and tightening the bolts (but not too tight) in a cross pattern.
Again, thank you for the suggestions.
Chris
HealeyRick
Here's a torque guide for various bolt grades: https://raskcycle.com/techtip/webdoc14.html Assuming you're using a zinc-plated, grade 5, 3/8 - 24, use 30 ft-lbs. (The table at the bottom gives correction factors for plating.)
Roger Menadue supposedly never used a torque wrench, relying on his mechanic's "feel". I have absolutely no argument with John's book value, but I prefer "real tight" as specified by Steve Gerow.
M TR2/3/3A HVDA Speedometer Drive Triumph 10
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
B MGA Tach drive issue MG 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
3798j Off Topic MGB at the Drive in Bank MG 1
Popeye General Tech O/D right angle drive choices Triumph 10
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
AngliaGT Mixture of Cars on My Drive Today Spotted 8
drooartz MGB First drive of the year! MG 5
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
DocDup1 MGB SpeedBox Speedometer Drive MG 0
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
BritBite Speedometer Right Angle Drive Austin Healey 5
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AngliaGT On Today's Drive Spotted 0
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D T-Series Shorrock supercharger drive belt MG 7
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
D Off Topic Remember to drive your Triumph Triumph 3
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
R TR6 Drive shaft orientation Triumph 3
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
KVH General Tech Angle Drive Broke (Repost) Triumph 0
KVH General Tech Angle Drive Came Apart Triumph 10
R TR6 1973 Final drive issues Triumph 5
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
C Bugeye propeller/drive shaft- universal joint Spridgets 1
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
nichola TR6 Oil pump drive barely engages Triumph 2
T Angle Drive Lubrication Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
L TR2/3/3A Drive shaft question Triumph 5
Lin Tach drive housing for BT7 Austin Healey 4
4tecdog Speedo drive gear Spridgets 15
RJS TR4/4A Speedometer and Angle Drive Triumph 6
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
mctriumph Morgan drive line Other British Cars 2
S Speedometer Angle Drive Austin Healey 2
D It's enough to drive ya to drink.... Jaguar 4
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
Healey Nut Mechanical tach drive Austin Healey 2
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
