[ QUOTE ]
Thanks. Dave. I got it all apart except the bearing. I cannot figure out how to remove it. -- I'll check the parts stores to see if they rent or loan the 2 13/16 socket.
Interesting.. this nut screws the normal way, clockwise tight. It is on the right side of the car and the wheel hub nut goes the opposit way. Moss list right side and left side nuts. Could the PO switched them????
[/ QUOTE ]
Guess you missed the part about maybe the seal isn't leaking. Anyway, full speed ahead.
The wrench is a 2 and 13/64 socket, not 2 13/16. It is 8 sided not 6 sided. Very strange tool. You can get it here, part # BCS T12, but they want $65 for it. It DOES have a nice square cut end with no entry taper & fits very well.
https://www.britishcarspecialists.com/
Don't attempt to remove the bearing. If you distort the hub even a little bit you are in real trouble. New hubs are very hard to find & expensive. Take the hub & half shaft to someone who has the right equipment & let them change the parts. I know it is a long haul to almost anywhere for you but call around till you find someone in Reno, or Sacramento that is confident they can do it without bending the hub. Personally, I would take it to Norm Nock in Stockton, same place that has the expensive wrench.
Straying a bit off topic here; Moss is correct, RH thread goes on RH side, LH thread on left side. The torque reactions are opposite on the nut from what they are on the wheel spinner. The hub nut tends to tighten with forward rotation of the wheel. The splined wheel hub applys force on the spinner that is actually backward to the direction of wheel rotation which tightens it. Don't try towing a splined hub car backward, like having the rear wheels on a dolly & the front ones on the ground. The spinners will unscrew.
A partial quote from another source:
"One of the endearing mysteries of the wire wheel is that the spokes are not ... indeed, can never be ... in compression, the weight of the stationary car is suspended from those spokes which are uppermost in the wheel. when the wheel and locking cap are loosely fitted, therefore the upper portion of the outer taper is pulled firmly into contact with that of the locking cap taper, and the lower portion of the locking cap thread is in contact with that of the hub. A slight clearance then exists between the tapers at the bottom, and also between the threads at the top. As the car moves forward, a different portion of the wheel rim takes the weight, and relative movement occurs between wheel centre, locking cap and hub. The effect of this is to tighten the locking cap, and the locking action continues until there is firm contact between the tapers all round, when it ceases. The clearances involved are, of course, minute, but the locking action is nevertheless, completely positive and entirely automatic."
Make sure that the axle housing surface that the seal runs on is very smooth. Polish it with a bit of crocus cloth if necessary.
