M
Member 10617
I knew how to drain and refill my TR3 transmission before I had an overdrive added, but now I am almost completely in the dark.
Can someone give me a quick lesson on how to do this?
I know where to fill the transmission (gearbox)-- no longer from the cabin but now from a plug in the side of the transmission. But now with overdrive there are two drain plugs(?) -- one the normal size under the transmission and the other larger with indentations all around the plug, located below the overdrive unit. When draining the transmission with OD, do both of these plugs need to be opened? Why two drain holes?
And when refilling, does the fill hole in the transmission also fill the OD portion?
ALSO: Is it even necessary to drain and refill the transmission (Gearbox) or just top it off every now and then. Some manuals recommend only topping off and not draining until unless the unit is overhauled. In automatic transmission cars, the transmission needs to be "flushed" now and then to maintain proper velocity.
I'm not having any noticeable problems, but just want to know how to conduct routine maintenance.
