JimLaney
I'm working on on the body of my '65 Mk III and I discovered that the left rear wing holds water and drains very slowly. The trunk floor has a hole in the right side behind the brace and above the opening to the wing below.
Should I drill a similar drain hole on the left side to allow the water to drain from the left side? Or is that a big mistake?
I think the water is trapped in left wing. It drains very slowly with a lot of brown rust in the water.
Any experience with solving the tin worm problem?
