Guinn
I started a "simple" job this evening: Drain, flush and refill the coolant in my 78B. What idiot re-designed the coolant system and, better yet, Why? There is no radiator cap, no engine drain plug, no radiator drain plug! I knew it was like that before I started but thought I could out-wit the system and do it all in an hour. Yeah.
I pulled the radiator hose loose at the engine, then pulled the lower hose loose, getting a faceful of Prestone in the process. Replaced the lower hose and tried to pour coolant into the engine at the thermostat housing. Got a cupful in and realized I had to remove the thermostat. Poured a gallon or so of water in, closed it up and ran the engine for a couple of minutes. Opened it back up, drained the water out, repeated above. Water was quite clear, no rust, no crud. I have now refilled the block with Prestone but need to put some in the radiator too.
Is there a better way to fill the radiator other than just up-ending the hose and pouring it in there? Is there a better way to do this whole job? Any help will be appreciated.
Guinn
Guinn
Hi Guest!
