DOT 4 vs DOT 5
Carmine
For a winter project, I am rebuilding clutch master cyl and slave (master cyl fluid was black). I am also replacing rubber brake lines in the rear of my 74 TR6.
Now would be the time to change over to DOT 5 if I am ever going to do so(I would also rebuild the brake master cly and rear wheel cyl if I changed over). I have read about the differences on other list, but I would like to hear your opinions on the subject.
I put about 5000 mi a year on my 6. It is in storage of only 3 months a year.
Dale
Haven't gotten around to the brakes yet but when we put the rebuilt engine back in my 7 we also rebuilt the clutch slave and master cylinders and went with the silicone fluid. Can't remember the specifics as to why, but it seemed to be the way to go from all that we'd read about it on this and other places. Seems to be working out fine at 6000 miles since 4/21/02. Will surely use the silicone fluid when we do the brakes.
TR3-2001SE
I am all so interested as I am completely redoing the brakes on my TR3. I understand from another post on this fourm that the dot 5 is the way to go if you completely redo a system. It doesn't corrode the parts as bad as the Dot 4. The down side is some people say the pedal has a little sponger feel than the Dot 4. It also boils easier which should only effect you if you race or live in the mountains. All this information comes from another post of this forum.
piman
Hello Carmine,
I agree with Dale on this, I have used Silicone brake fluid for about twenty years and would use nothing else on a road car.
It does not degrade with age (It does not absorb water as conventional mineral fluid does) and also does not corrode the cylinders, particularly useful if the car is stored. It does not lift paint when spilt on the body but it is quite a bit more expensive to buy. Worth it though in my opinion.
Alec
MDCanaday
Carmine , the real problem is the natural rubber seals that are the heart(and achillies heal) of the system. Castrol LMS and silicone are the only safe options.Every other conventional fluid degredes the seals in short order, leading to sudden failure. I sugest the silicone for normal uses, the LMA for more serious driving.Of course if some brite lad came up with modern seals to re-build our LBC's brakes life would be much simpler
MD(mad dog)
maueman
WOW... didn't know silicone fluid was around that long??? Main thing for me was the fact that it doesn't EAT PAINT!!!!!!!!!!!!!
t8nwa
I re-did my clutch with silicon back in 1987 and never had trouble with it. I heard something bad about using it brake lines but I do not remember what it was. Propably not that important.
A
aerog
I understand it (DOT5, although I'm not sure about 5.1) isn't desireable in ABS systems. Unless we're talking about new/modern vehicles this isn't an issue.
There are also other negative comments regarding moisture absorption; since silicons don't absorb moisture, any moisture left in the system will be allowed to pool and concentrate causing localized corrosion and eventual failure in those areas. If you're rebuilding an entire system this shouldn't be a factor, and if you change the fluid out and clean the system I would think the moisture would evacuate itself.
Trevor Triumph
I changed to DOT 5 in my early Spitfire several years ago for the reasons stated... no threat to the paint, and less corrosion. I have noticed that the silicon seems to be thinner than other brake fluid and hence leaks around some seals. Is that possible? The left hand rotor and caliper has a residue of brake fluid on it and the car pulls to the right when I apply the brake. I clean the rotor and pads and we're stopping straight again for a while. I don't think film of fluid is left over from bleeding the system. T.T.
A
aerog
I'm not sure if DOT5 is thinner, but I've read conflicting stories about replacing DOT3/4 with DOT5. Some people swear you have to replace or rebuild the cylinders/calipers and replace the flex lines. Others just flush the system to replace all the DOT3/4 with DOT5. Seems like the people who replace everything have fewer problems but who knows.
Rick O.
Few things to note: Get a gallon of denatured alcohol (ethanol) from Lowe's and run it through the system to remove the glycol and water. Then add the DOT5. Another is that you'll still have to renew the DOT5 every couple of years because water still gets in the system (it just pools). And finally, invest in a MityVac to bleed the system (wrap the bleeder screw threads in teflon tape first).
MGTF1250Dave
Aloha Carmine,
I found this interesting discussion regarding brake fluids on the internet.
https://www.icbm.org/erkson/ttt/silicone.txt
The idea of recycling the DOT 5 silicone brake fluid was something new to me. The article also has a detailed discussion of flushing your system and tips on bleeding the air out.
Safety Fast,
Dave
MGTF1250Dave
Aloha Scott,
Although my sense of smell is not that good, I can tell you that DOT 3 & 4 have a "banana oil" ester smell that reminds me of plastic model airplane glue from my youth. I can only say that DOT 5 doesn't smell like that. I don't have a good discription fpr DOT 5 other than it has more of a motor oil smell.
DOT 3, 4 & 5.1 are all glycol and glycol ether mixtures. There is also some brake fluids out there called "super DOT 4" and this is apparently similar to DOT 5.1. DOT 5 has a silicon chemistry. DOT 5 is also required to be purple, however the dye is only required to be stable enough to stay purple until it is poured from the original container. It is reported that over time (2 years or so) the DOT 5 in your car will lose the color and become clear or slightly amber.
DOT 5 is reported to be a good lubricant between medal and plastic and metal and rubber contact points which reduces wear. ABS brake systems apparently have some metal to metal contact points in them, DOT 5 is not a good lubricant in this situation, therefore not recommended in these systems.
DOT 5 is slightly compressable and might result in a spongy pedal feel, particularly in hard braking situations. This may make it unacceptable to some for racing applications. Additionally, since water and DOT 5 do not mix, water intrusion into the brake hydraulics (especially at caliper and wheel cylinders) will reduce the fluid boiling point from 500 deg F, to that of water.
The source for this information are various internet sites and Vintage Triumph Registry.
Safety Fast,
Dave
RCS
Hello All,
Regarding the smell question, might I suggest a lot like the bimbo from baywatch...
Seriously, you folks seem to have it figured out pretty well, wish I'd read this when I started.
Silicone fluid is DOT5 and there is also DOT5.1 which is not the same, totally different stuff.
Previous post suggested flushing system with isoprproyl alcohol, excellent idea, even better if you find 91 or higher, percent alcohol, less water. Highest I have found is 98, at a paint supply house.
When filling system, biggest trick is pour slowly, and let sit to allow bubbles to evolve. Dot5 is a bit thicker than other fluids, and tends to hold bubbles in suspensiou for quite a while. Rushing things may migrate these throughout the system, thus the "spongy pedal syndrome"
Changed the fluids in several of my cars, loved the results. Worked well, lasted a long time! Never raced the stuff, but was driving in the mountains at the time...
AUSMHLY Castrol DOT 4 vs Other Brands Austin Healey 6
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
R TR2/3/3A Dot 5 Triumph 8
KVH General TR Dot 4 Brake Fluid Triumph 7
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Rhodyspit75 DOT 5 and DOT 5.1 Spridgets 1
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
S TR2/3/3A Question on the lift dot fastener, Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
T TR2/3/3A Lift the Dot question Triumph 4
TulsaFred Timing Gears dot to dot Spridgets 9
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
NutmegCT brakes: DOT 3 or DOT 4? Restoration & Tools 2
C TR6 Dot 5 in a TR6 rebuild Triumph 17
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
S dot 5 brake switch Triumph 14
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
C Converting to DOT 5 Triumph 6
Steve_S The New M.G. Nuts dot com MG 1
CJD DOT 5 Brake Fluid Triumph 38
M Removing Lift-the-Dot Fasteners Triumph 8
tahoe healey DOT 5 going away? Austin Healey 8
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bighealeysource Push the Dot post on dash of BN6/BN7 Austin Healey 1
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
C "Lift-a-dot" studs Austin Healey 9
ekamm lift-a-dot studs Triumph 8
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
Brosky Stag Trimph TransAmerican Stag pics added to DOT Triumph 24
dklawson New Brake MC & Warranty with DOT-5 Fluid? Triumph 41
davidk Flushing DOT 5 Fluid Triumph 5
H TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR Triumph 4
dklawson A-Series Dot-to-Dot Cam Setting [TDC?] Spridgets 3
J dot 4 brake fluid Other Cars 4
M Dot brake fluid, question Spridgets 10
S DOT 3 or DOT4 Brake Fliud Triumph 44
Brooklands Lift the dot fasteners Restoration & Tools 8
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
Harry_Ward Lift the dot stud type for tonneau cover? Triumph 13
Trevor Jessie 4 year old dot dissappointed with steering wheel Spridgets 4
G Dot Snaps Triumph 2
