A recent corrrespondence with apple hydrolics, at the end I ask about silicone brake fluid,
Lazar
Apple Hydraulics
https://applehydraulics.com
1610 Middle Road, Calverton NY 11933
800-882-7753, 631-369-9515 (voice)
631-369-9516 (fax)
> Sir
> I have a 1956 Triumph Tr-3. The master cylinder needs
> to be rebuilt {resleved}.
1956 is split year, critical commission number is TS13045:
- early master is clutch+brake combo master ($195 for
complete rebuild with brass sleeving, for stainless add $25),
- late master is separate aluminum brake master ($95
w/brass, $110 w/stainless, but note that Moss etc. sell new
for something like $99
> I want a complete unit ready to instal out of the box.
> I have a complete, not frozen, core and will send it
> to you. {It is missing the fill cap, is this a
> problem?
OK, I guess yours is early type (later type has remote
reservoir, so cap is not part of the cylinder).
New, plastic cap $6, good used original (metal) cap $10.
> My question is when I send the core to you, can I
> include my credit card info in the same container?
> can You make the apropriate charges to the card # and
> repair and return. OR is there another "Prefered" way
> you would rather use?
> P.S. I plan to ship the core U.P.S.
Ship with whatever shipper is convenient to you, they all
deliver here. If paying with Visa, Mastercard or Discover
either include card info with the parts or ask that we
contact you for it - card is run on the day of return shipping.
> Please respond with your prefrence on conducting this
> transaction.
> This car will be an occasional driver, {Not everyday
> by no means} and will deffinately be sitting idol
> during the winter months, 6 months out of the year
> here! and maybe driven once or at the most twice a
> month the other 6 months. Short distances at that!
> So your recomendations on brass or stainless sleeves
> Is fine by me. Not worried about the extra cost. Or
> frequency of needed rubber replacement.
brass requires same care as original cyls (brake fluid
change), stainless does not, but steel is more abrasive
(harder on rubbers), so seals go out faster (and that's why
steel is not used to make brake/clutch cylinders!). If you
will actually use the car, go with brass, if it is for
parades and not much more, go stainless
> One other thing, wondering about silicone brake fluid
> Yes or No. All brake lines and wheel cylinders clutch
> lines and slave are new {they have never had any type
> of fluid in them.}
Note that new parts and rebuild kits are tested and
compatible with fluids originally approved for the car and
that does NOT include silicone fluid (DOT 5). We do not
guarantee that our rebuilt parts will work with DOT 5.
