TR5/TR250 Door Striker/Latch Adjustment
glemon
After having a lot of trouble with my door striker plates last year I figured out (or more likely finally remembered) that the catch has two stops, the first a safety and the second should hold the door shut tight. Once I started moving the striker plate out instead of in I made progress, however, after jacking the car up to flush the brake fluid yesterday (went too easy, I ew there had to be a catch) the driver's door is once again giving me trouble. Is there a way to adjust the catch mechanism in the door, or is the only option moving the striker plate?
Please note, pretty sure it is the same as tr4A and TR6
Maybe the problem is with the frame that supports the body of the car...have you checked for cracks ?
Do you have shock absorbers different from the original Armstrong lever shocks ?
My opinion is that the internal mechanism in the door has no adjustment feature. And the mounting holes in the door also do not allow any adjustment.
So you are left with the sticker plate and adjusting the entire door at the front hinges.
Charley
Shocks are a tube shock conversion, nothing is cracked in the frame though there is some flex when the car is jacked up depending on jacking point. I figured the plate and hinges were the only adjustable parts. Will keep plugging away at it.
