TR6 Door Panels
sundown
Hi I just recieved my new door panels from Victoria Britsh are there any tricks to keeping the panel compressed against the spring soyou can place the 1/8 pin into the handles I really donot have anybody around to help at this time Thanks
DNK
Some don't reinstall the spring
"Nother trick is to use a coat hanger as a pin.
Cut 3/4 the way at the proper spot.Stick it in the handle hole and bend it and it will break
Gliderman8
After wrestling with the same scenario when installing my panels, I decided not install the springs; even without the springs, it was still a PITA. I used a tapered pin that I bought in the local True Value store and have not had any issues at all with them.
sundown
sundown
The problem I'm having is without the spring for pressure the door panels will not snug up against the handles
DNK
My thinking on that is to put something behind the panels to push them out
Like a spring
TR4nut
I've worked out a method that has done well for me: I install the spring as normal, install the panel, install the plastic escutcheon, and use a scratch awl to locate the hole in the handle and press hard on the handle into the door until the scratch awl locates the hole in the window winder shaft. Basically the scratch awl holds everthing in place where it is supposed to be. Then I take a small needle nose, or use a hemostat like what TR6easyrider uses, and get the pin in position on the opposite side of the handle. Start the pin in place, and very slowly withdraw the scratch awl. Hard to explain and takes some practice but it is workable.
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
Marvin Gruber BJ7 door panels Austin Healey 4
R Wanted TR6 Interior Door panels Triumph Classifieds 0
I Best glue for rubber door panels? Spridgets 3
S TR2/3/3A rebuilding door panels Triumph 15
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
bugedd Door panels wanted Spridgets 2
BOBBYR Body panels and door gaps Austin Healey 5
Tinkerman TR2/3/3A TR 3A door panels Triumph 13
sundown TR6 door panels Triumph 4
T TR2/3/3A Installing door panels Triumph 4
B WOO HOO! Doors are finished! Finally got the panels on, door pulls, handles & cranks Spridgets 9
B Clips for door panels..79 Midget Spridgets 1
CJD TR2/3/3A TR3 Door Scuff Panels Triumph 4
Brinkerhoff BJ7 door panels Austin Healey 2
W SEM Color Coat and ribbed door panels Spridgets 13
W Heritage Trim BE door panels Spridgets 0
histerical Bugeye door panels Spridgets 7
T Wedge VickyBrit & Roadster Fac TR7/8 door panels same? Triumph 2
longbridgehealey Inner door panels on a 100-6 Austin Healey 7
I interior door panels Spridgets 5
H door and rear quarter panels BN 7 Austin Healey 1
B 79 Midget door panels Spridgets 5
Z 68 sprite door panels [and working tach now] Spridgets 3
Atrus Interior Door Panels Spridgets 17
B Door Panels Austin Healey 7
R Installing inner door panels on a BJ-7? Austin Healey 8
jaybird Up-date -- carpeting, door panels & seats! MG 10
R Door panels MG 1
B Door Panels Roadster Austin Healey 0
Bob Claffie Door panels Austin Healey 11
P Removing BJ8 Door Panels Austin Healey 21
Paulus TR6 TR6 Door Panels Triumph 5
R Door panels MG 2
MrBlueSky Wedge TR7 Door Panels Triumph 3
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
