Door panel material
hottvr
What have you guys used to make your own door panels, and what tool did you use to cut the material?
Thanks
Rick
I have used an upholstery grade cardboard ("tagboard"), covered with marine grade vinyl. Not a real original look, but OK for an everyday driver. I cut the board with a sharp knife or a saber saw. I have also used thin Masonite.
Good Luck with whatever you are working on!
Bruce
The door panels on my Morris Minor Traveller are wood panelling, thanks to the DPO.
I've used 1/8th inch hardboard, and plywood as a base before - jigsaw works nicely. Box cutter, or scissors for the vinyl.
Funny thing - I bought a GT once that had beautiful Luan panels in it - still have them
But, I go to local upholstery shop & buy panel board to make new ones though Moss kits are probably cheaper when everything's said & done (especially when they're on sale)
Coroplast might be a good substrate too. - and more resilliant to water.
Coroplast may "dimple" or get kinked too easily. I used a polycarbonate plastic on mine. Cut it with a "Skil-Saw".
[ QUOTE ]
[/ QUOTE ]
How'd you fasten the vinyl to it?
Glue works too.
I'm kinda curious, Rick - why make your own?
I made mine out of a water-resistant material that looks like 1/8" thick shirt cardboard. Got it an an auto trim shop. It may the "tagboard" that bcliff talks about. It was fairly easy to cut with a utility knife, and I just glued the vinyl to it. The trim shop made a doorpanel, duplicating an NOS panel I had. I don't have the equipment to stitch the piping into the vinyl. I made the rest of the panels. I went that route because no one would make me a deal on a '69 panel set!
All good reasons - I was just wondering.
Thought about making my own also. I like making stuff. Means more to me than saying look what I bought. I 'd rather say look what I hand crafted.
