Lotuswins
Hello,
New member here, Jerry Rude in Roseburg OR, with a BJ8 under construction. I'm fitting the panels for the 2nd time, apparently once wasn't quite enough, and have a question about door gaps. What is the acceptable range for them on the Healey??
I measured my wife's S-type, and they are between .140 and .170. The Dodge Dakota is between .170 and .240. Measuring the Europa is out of the question, I'm just lucky the door fits into the hole :^)
Presently the BJ8's left door, the problem child, has .400 at the bottom, and .060 at the top, on the front edge. The rocker panel edge is about .060, and the rear is tight against the fender, but at least it is constant. I figure I'll have to modify the front fender, and bend the hinges to bring the door forward, so if I do that, I figure I'll have a little less than .200 inches if I remove some material from the front fender and move the door forward. Is this an acceptable gap??
The other side is pretty good, at about .125 or so front and rear, and bottom at about .060 once I move the door up and secure the rear fender.
Thanks for any thoughts on this subject......I'm getting close to final body work, and I'm getting excited about final painting......I'm 8 years into a 3 year restoration.....
Jerry Rude
1967 BJ8
1973 Lotus Europa
Jerry Rude
1967 BJ8
1973 Lotus Europa
Hi Guest!
