BTW Happy Easter all! I spent a couple of hours taking off the driver's door tonight. It actually came pretty smoothly. However, I'm not exactly sure,
1. How to remove the key cylinder from the door and
2. Is there any way to remove the backing plates for the door latch on the body and the backing plate for the seat belts. These are the plates the bolts bolt into. They are all loose and I got the lower one off (that the "knob" on the door jamb slides into)I'm planning on having the body shot blasted and I suspect these plates will get damaged.
Thanks for your help
JP
JP
Hi Guest!
