Door Check Strap
stefano rosati
Hello everyone, the right door of my 100-Six Healey does not stay open. I have already changed the check strap twice, but the screw soon loses the thread and the door does not stop anymore. Do you have any advice? Thanks and greetings.
Re: door' s check strap
Sounds like the nut has stripped out. I once made one out of a standard LH nut by cutting a shoulder (using a lathe) on the bottom. I think nowadays you can buy all the individual pieces__except the stud may be part of the whole assembly, IF THAT's the piece that's stripped.
S
stefano rosati
Thank you, but my problem is to understand why the nut or pin are flipped because I already bought three kits without getting a result. To be evaluated that at the first assembly the door keeps, but only halfway, greetings Stefano
Grazie, ma il mio problema è capire perché il dado o il perno sono capovolti perché ho già comprato tre kit senza ottenere un risultato. Da valutare che alla prima assemblea la porta mantiene, ma solo a metà strada, un saluto Stefano
RTaillieu
The check straps are handed, they have LH and RH threads depending on which side they are on.
When you open the door the movement tightens the nut and puts more drag on the centre disk, that friction holds the door open.
When you chose the door the nut loosens and the door moves easier.
If I remember correctly the left door has normal RH thread and the right door has a LH thread.
Also don't use any lubricant on them.
steveg
I've also had the right-hand nut (LH thread) strip. A few years ago I bought some 5/16-24 LH nuts from a fastener supplier and used the setup in the pix instead of the shoulder on the stock nut.
First LH nut still working fine.
Used a lockwasher for a bushing on the friction pad.
For the spring, found a 5/16" ID brass bush off which I cut a slice. Another lockwasher probably would have worked here.
S
stefano rosati
I'll try to put those washers. Thanks a lot and greetings Stefano
Proverò a mettere quelle rondelle. Grazie mille e tanti saluti
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
sundown TR6 Door check strap Triumph 3
K door check strap Spridgets 10
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
W Broke check strap on door Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
6 door check strap Triumph 6
R TR4/4A Door check straps Triumph 7
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
KVH TR4/4A Door Check Straps Triumph 11
Michael Oritt Door check installation Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
M BN1 door check replacement Austin Healey 9
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 1973 TR6 door check straps Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
G 6 door check noise Triumph 13
A Door check Lotus 4
S TR2/3/3A door check straps for tr3 Triumph 1
mjobrien Door Check - Color? Austin Healey 2
S TR4/4A TR4 Door Check Straps Triumph 4
This14u Spitfire Spit Door Check Triumph 3
I TR6 Removing door check arm in TR6 Triumph 6
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
