T-Series Does this sound like clutch problems?
William
Okay, so Dad's been mentioning a weird thing happening with his 1971 MGB roadster. Says that the clutch feels like it's slipping at high rpm's, usually when accelerating. I've only driven the car a few times this season, and hadn't experienced anything. He and I went for a drive today (just got back a minute ago), and it happened. We were driving along, probably about 40 or so, and he nailed the gas. We were at about 2500 RPMs, but around 3000 or 3500 the revs seemed to flare up to 4000 or a bit more before he lifted. They dropped right back to somewhere int the mid 20's. This happened twice, the first time he was actually passing a car and it certainly felt like we were accelerating. The second time it did not feel like we gained any speed at all.
A whole bunch of work has been done on this car this spring. Engine and trans mounts were all replaced due to oil leaks ruining them. and all sorts of engine and trans seals were replaced because of leaks, plus a new clutch cylinder (I think it's the master, but I could be wrong). At all other times-like driving in town and working your way up to speed rather than nailing it to pass-the clutch feels fantastic, really good bite and it certainly doesn't feel like it slips when you decelerate. I do not believe that the clutch itself was replaced, and I'm hoping that it just got contaminated by oil or something during the rebuild that needs to wear off, or that maybe the new clutch hydraulics are wonky. Any other ideas? I'm stumped.
-William
PS- all the work was carried out by a very highly respected foreign old car specialist that's been in business for years and years and so far (in both my Midget ownership/repairship and with Dad's B), never done something incorrectly or on the cheap.
A
aerog
Ditto what Steve said... without the OD it narrows it down a bit. It may not be a worn clutch, but just as bad (sort of) an oil leak dropping oil onto the clutch. Either way it's going to take pulling it apart to fix.
W
William
Yeah-can't get the symptoms to occur on a regular basis. We tried again tonite to no avail. Everything feels fine in first and second, this has only happened in third and fourth, and not consistently. There's one new wrinkle, though-when we got back, Dad decided to check the oil, and we had a look around the engine room. The nice shiny new clutch master cylinder (for it was the master that was replaced) seemed to have something on top of it-you know how those metal master cyls have the screw on top and a big shoulder on top. Turns out the cap was loose-Dad was able to tighten it right up, and the liquid was hydraulic fluid by the yellowish looks of it. Makes me wonder if we were lacking a little extra clutch pressure because of this.
-William (keep 'em coming!)
A
aerog
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by William:
<hr></blockquote>
Unfortunately it doesn't work that way. The hydraulics simply provide a way to overcome the springs that hold the clutch in position. Lack of fluid, and thus pressure would result in the inability to shift gears (or at least a quite difficult time of shifting).
My guess is in third and fourth gears you're able to get enough torque on the engine side to spin the engine against the clutch - again, a symptom you can probably recreate by holding the brake while trying to move the car in third or fourth gear.
coldplugs
Platinum
Ditto and ditto. I don't think there's any adjustments to play with. Most likely some oil got in there & is causing the slippage. Chances are you'll really notice it going up a long hill in third or fourth, and possibly smell it, too. Unfortunately slipping clutches usually don't get better by themselves. You said that the fellow who worked on it knows his business, so it's probably not in backwards or anything like that.
John C
J TR6 Does this sound ok to you? Triumph 5
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
T why does a Healey exhaust sound the way it does? Austin Healey 21
gsalt57tr3 How does your Triumph sound? Triumph 21
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
