I have only replaced them, as they are not the easiest to put back together once taken apart. You can cross them with GM pumps from a small 4cyl car. I take the Jags into my parts man and he hands me one from a Buick. Check and see if your bolts are metric, if they are get a metric pump.
If you leave it on, you should have a look at the check valve and diverter valve, just to make sure they're working right. A diagnostic is described in Haynes I think. Pretty easy to check. If the check valve fails, I think it might shorten the life of the pump.
