100DashSix
I'm trying to determine if I should replace my clutch slave cylinder. There is slight surface scoring on the piston and some corrosion of the bore near the lip. I'm not sure if the corrosion is far enough in to allow fluid to leak around the seal, however.
(click for bigger)
This is the slave cylinder bore with the piston removed but the seal in place.
This is the slave cylinder piston.
The master cylinder is in a similar state, but the piston is in much better condition.
I've got photos of the ongoing project here: https://antichipotle.com/clutch.
The fluid itself was an awful greenish color, with some particulate deposits junking things up.
(click for bigger)
