Do BJ8's suffer from skuttle shake?
John_Progess
I'm restoring a 64 BJ8 and have read about skuttle shake. I am at the point where I could do something about it if it is a problem. Is it a problem and what is the solution? Thanks for your help.
John
Hi John,
Scuttle shake seems to be a general term applied to cars, especially Healeys. True scuttle shake is vibration of the scuttle (cowl) & dash when going over rough road surfaces. It is often used to describe any vibrations in the body, especially in the front sections.
Any topless car is subject to more body flexing when traveling over rough surfaces due to the lack of a supporting top structure. The panels on an open top box obviously can flex more than if the top of the box were closed.
The Healey with it's semi uni-body construction is considerably more rigid than separate frame-body designs. Some of the other un-named brands with separate frame-body construction are notorious for chassis flexing. When one end is jacked up the doors will bind so that they can't even be opened.
Later model Healeys 4 seaters are more subject to body flex than the old two seaters. This is likely because of the increased wheel base, body length, & larger open area on the top of the box.
Flex on all of the models can be greatly increased by thinning/weakening of the original inner body, floor, frame structure, caused by rust. Many cars that look perfect on the outside have rust weakened inner structural parts. The Healey structural components were thick enough to resist most flexing when in new condition, but just barely. Any thinning - weakening of original metal results in more than the intended design flex. This is the main reason that a good Healey restoration may cost much more than it would on some other cars.
A "sound" Healy should permit jacking under any frame/suspension corner without any changes to door or panel gaps. Jacking under a side frame member should not open the top door to body gaps. A good test for overall soundness of the frame & underlying body structure.
Several other problems can contribute to body vibration that "may" be called scuttle shake although they show up at certain speeds & are not necessarily related to rough road surfaces. Some of the causes are unbalanced or out of round wheels or tires, out of balance brake drums (fairly common on the later models), weak shock absorbers, & loose suspension parts.
Various remedies such as reinforcing the area around the forward transmission tunnel to firewall to stiffen up the box opening have been known to help.
If a car passes the corner jacking test it is unlikely to have serious underbody-frame weakening. The only "real" cure for flexing is to remove the body panels & most everything else & replace the structural members with new metal.
As a note of interest, I recently added a very solidly mounted hardtop to my BN2. Although the car is pretty solid & flex free, there is a slight but noticeable increase in body rigidity.
ATTACHED is a pic of a Healey chassis. All of the parts shown are welded into one piece. The body panels are mostly just hung on this structure & don't contribute much to overall rigidity.
The above is my take on the problem, others may not agree,
Well said, Dave. John, if you’re in a position to replace weakened chassis parts, probably everyone would agree to do so.
If you’re well past that, you’ll want to ensure moving parts are balanced: Wheels (should also be true), brake drums and the drive shaft.
[ QUOTE ]
John
[/ QUOTE ]
Hi John, Yes the BJ8 can exhibit scuttle shake. However, there is no smoking gun solution for a fix since it can be attributed to several sources.Make sure the bodies supporting structure is solid and the front suspension is carefully rebuilt and you probably will be good to go.---Keoke
Generally the vibration shows up between 55-65 mph. New wheels and tires substantially reduced my shake, but some still exists. The next step for me is to have the tires balanced ON THE CAR. After that probably true the rear brake drums and the drive shaft.
Thanks to all for your information. When I got the car, mostly assembled, out in the snow & rain the last 10 years, I noticed that the doors did flex, about 1/16", when I jacked up the car from the rear. I also found that ALL the flat sections of metal needed replacement, all sills, rocker panels and shut panels were also bad. I have ordered all new parts to be welded to the frame along with a few places on the frame rails that have been repaired. The inside of the frame rails that I could see looked remarkably clean of rust. New wheels, tires, complete front suspension purchased and drive shaft is balanced. Is it advisable to balance the flywheel and clutch assembly for these cars? Thanks again!
John
Yep John, balancing the clutch and flywheel as an assembly is a right smart thing to do.---Keoke
