Jim_Gruber
I've been having some timing issues and finally resorted to doing some static timing this AM. The micro adjustment wheel on my 25 D Dizzy was turned all of the way in one direction. I adjusted several turns 5-10 back the other way and then reset static timing. I'm now noticing the vacumn advance cannister seems really loosely fitting in the dizzy. Meaning I can phyically pull on the cannister and get the vacumn advance to move. Doesn't the Vacumn advance housing sit firmly in place, possibly bolted in place or is it just a friction fit.
If this thing is all loosey goosey this could explain why I can't get Bugsy to run correctly. Starts fine and then give it a little gas and it misses. Keep above 2,500 RPM and it pulls fairly strong. No power below 2,500 or so.
How does the vacumn advance fit into the dizzy. Bolted or friction fit.
