Dizzy off to Jeff
jlaird
Today I sent Miss Agathas dizzy off to Advance. Spoke with Jeff as well, will be a couple of weeks.
Miss Agatha was missing a bit at 3K RPM and I suspect the vacuum advance. Told Jeff to work his magic, heh.
In any case this is one of two items that have not been renewed on Miss Agatha, the other is the rocker arms.
Gota have her running good for the show in New Orleans and the summer fun.
Jack, what have you done to Miss A's engine? Any goodies in there? Head work?? :confuse:
She is .60 over so 998cc and has a 1275 header, thats all.
However I do have a 295 head and H2 carbs on the shelf.
Jack
Put that 12G295 head on instead of sitting on the shelf. One of the best heads on a 948 engine
Cheers
Mark
Yep I know but I need to measure the internals first to determine how much to cut off of it. Thought I would do it when I pull the engine end of next month.
Jeff does good work. Between the rebuilt HS1s (done by my personal mechanic aka dad) and the like brand spanking new distributor, my bugeye is running like a top. Started right up in a 32 degree garage after sitting two weeks!
You will be very happy,
Brian
