Yesterday on the way back from Akron the 3000 developed an intermittent mild miss, as if one cylinder was misfiring. This morning I removed the distributor cap and saw that the nut securing the contact set was a bit loose--I tightened the nut, replaced the cap and went for a test run. I got about 1/4 mile and the car died. I again removed the distributor cap and the rotor was missing.
I found one piece of bakelite and the brass arm on top of the distributor plate. Upon disassembling the distributor I found the arm rivet, the springplate that goes inside the rotor and another coil spring about 3/4" long laying in the body of the distributor --this was not an advance spring nor the spring under the cap contact--those were all intact. I can't find any springs in the distributor--any thoughts here? It is definitely larger than either of the above.
There was a fine shower of brass filings throughout the distributor--should I be concerned with the shaft bearing surface? Also the advance diaphragm was inoperative--who sells these parts? The distributor has the following numbers stamped into the body:
DM6A406620
PEG 560
DM6A406620
PEG 560
Hi Guest!
