CuriousGeorge
What special cares need to be taken when removing a distributor? I want to clean it and check bushings, etc.
hondo402000 said:if you disassembly completely. like pulling the tach gear out and the shaft and weights out make sure you mark the way the sloted piece that goes into the gear is orientated, its possible to get it 180 degrees out of phase, took mine apart and found the advance weights were rusted together, put it back together and and car wouldnt start had to pull the dist out again, at least you have only a 50 50 chance to get it backwards
Certainly shorter!TR6BILL said:I like my answer better.![]()
