So part of my rebuild consist's of changing the car to fuel injection, which I already have. With this I will no longer need point, vacuum advance, advance springs or weights, etc. The ECU will change timing and such. Still, I want to have the distributor in good working order to insure no problems mechanically. I once had a distributor shaft freeze up once causing the distributor hold down flange to break and the distributor come up and out of the engine.
Since my car 60 3000 BN7 has a mechanical tach drive I was wondering if I should just get it rebuilt or any other option?
John
John
Hi Guest!
