carpecursusII
OK, I recently purchased a distributor from Jeff at Advanced. My 4A was running with a 40480 dizzy (TR3), I got the proper 40795 dizzy from Jeff. He said set it 10-14 degrees at idle and I did my best to do that. The car ran fantastic for about 100 miles, then problems. It started to have a subtle miss and highway speed and coming up through second gear, then it got progressively worse to where the car would barely run. I initially suspected coil so I replaced it, no change. I suspected fuel because I think I mistakenly purchased fuel with 10% ethanol blend but the car has run thousands of miles before with blended fuel. On a hunch I pulled the old dizzy out and reinstalled it, timed, and drove. Ran fantastic, no miss.
When using a light, it appears that the dizzy from Jeff is not holding advance, I can see the mark dancing around about an inch along the circumference of the pulley when I bring the car up 2000-3000 rpm, at idle it moves 1/4-3/8 inch. With the old dizzy the mark moves around maybe a 1/4 of an inch or less at idle, and about the same movement as rpm increases, it is not rock solid but better than the new unit. I took apart the old unit and the plate shows 15 degrees stamped on it, I happen to have a spare set of springs around so I replaced them and noticed that the spring I removed were not the same tension.
So why does the new dizzy not work properly, I did check the weights and they move freely and the springs are not broken.
Absolutely!
