Tim_Creger
Dear Forum,
I've posted a few questions about my electronic ignition over the summer,and now have a whole new oddity to ask about. I bought a new Pertronix EI distributor to replace the original that quit working in my MGB ('72 car with a newer B engine). The previous thread was asking basic questions about static timing the engine, which I've done a dozen times with no success. Today I decided to see how the old dizzy and the new one matched up. With the #1 cylinder on TDC I installed the original dizzy and see that the rotor is at the 8 o'clock position. Everything I've read says it should be at the 1 o'clock position. I then installed the Pertronix dizzy and observed the rotor at the 2 o'clock postion, exactly 180 degrees opposite the original.
I pulled both units out, laid them on the bench side by side, matched up the offset drive dogs so that they were in the same position, and see that the rotors are 180 degrees opposite in position. I've never heard of this situation, and yes, I made sure that the drive dogs were correctly seated when I installed them, and that is why I did the bench comparison to make sure I was seeing what I was seeing.
Can anyone refer me to a distributor expert - I've seen some posts referencing someone, but can't find the contact info for that person.
Any help would be gratefully appreciated. I also posted a few photos for anyone to look at and tell me if I'm missing something obvious.
