Deleted member 19315
Hi all. A question if I may. My car has a slight oil leak from the base of the distributor mounting pedestal where it bolts to the block. Is there anything to be wary of when removing it like parts that can fall off into the motor. I'm just wanting to check it's all flat and fit a new gasket. I noticed someone has been there before and the current gasket looks homemade, which is fine but this one's not done well. I'll also fit a DW clamp for my Mallory dizzy while I'm in there.
Andy
Andy
