Atrus
Well, I've decided that I wanted to either get the Pertronix unit for my stock 25D, or get the whole new ignitor distributor by them.
As it's freezing cold, and I am going through withdrawl from not putzing around on the car, I mustered up some willpower, ran out to the garage, and yanked the distributor so I could make a good evaluation of it's condition.
I have a few issues that make me question which pertronix product to buy. The issues I have are below:
1) I snapped the vacuum advance line right at the nut on the advance unit. Anyone know where I can get a piece of the super tiny tubing so I can reconnect this properly?
2) I found one of the springs for the mechanical advance completely stretched out and just kinda floating around in there. I looked on Moss, it doesn't seem that they sell them. Is there somewhere to get the spring?
3) On the distributor body, where the clamp would hold it in place on the engine, there's a lip. It was noticeably bent inward. Not thinking, I tried to pry it back out into shape...yeah, I should have known cast aluminum wouldn't like that, and it indeed did not. So, I am now missing a piece of the lip, about .75" around the circumference. Is this going to cause me issues? I wouldn't think that it really would, perhaps an oil leak (although the o-ring should take care of that, correct?)
4) Shaft play - I notice none if I try to wiggle perpendicular to the shaft's axis. I do have some along the shafts axis, i.e. up and down in the housing. I assume this is normal and acceptable, we'd be worried about it having side play. Is this assumption correct?
Thanks in advance!!!
Hi Guest!
