DanLewis
I was surprised to discover today that the distance from the front of my 6-bladed plastic fan to the radiator core on my Bugeye was almost 4"! It's 5" from the water pump flange to the radiator, and the plastic fan extends another 1" from the flange. Even though there's a fan shroud, it really seemed unusually far.
Although I have a Chinese aluminum radiator installed, the mounting and core thickness is absolutely identical to the original equipment radiator that I still have laying around. I don't think there's anything odd about the water pump either - especially since the fan belt lines up properly between the water pump pulley and the crankshaft pulley.
I started looking for a fan spacer and ran across this statement on Summit Racing's website:
I'm now wondering if the large distance between the fan and radiator is diminishing the effectiveness of the fan at idle, contributing to the engine temperature rise I see at idle on a hot day?
Could someone with a Bugeye confirm whether or not the 4" distance between the fan and the radiator core is normal?
Thanks!
Dan
Belt-driven fans work best when they are 3/4 in. to 1 in. from the radiator's surface. Whenever you remove an original equipment fan clutch from your engine, you need to add a fan spacer. This will bring the fan back into the "sweet spot" in the fan shroud opening.
(See https://www.summitracing.com/parts/flx-14556)
Thanks!
Dan
